I've made a vertical wall assembly showing three different material makeups - a block base, a polycarbonate strip and metal studs with metal framing above. The materials show up fine in 'realistic' views but aren't showing up in 'shaded' veiws or in elevations - any idea why?
Thank you.
The screen capture you showed is of the Graphics tab. The Graphics tab only applied to Shaded and Constant Color display settings. Materials need to be set to the Appearance tab.
Howard Munsell
Ha! Well, that's two of us. You obviously read it the same way as I did originally. OP wants to see photorealistic materials in a non-photorealistic view (e.g. Shaded).
FWIW, @leahTMHX9 :
