Wall Assembly Issues
I originally wanted wood cladding on the interior of my space but now I just want white walls. Here is a screen shot of how my assembly is set up? Any ideas as to why I can't get them to show up?
MostafaElashmawy
there is two possibilities:
1- you are drawing the exterior layer at the inside of the building. try selecting the wall and click space to flip it to check the other side.
2- you may have the surface pattern of the paint material similar to that of the Oak.(may be you duplicated the Oak and forgot to edit the graphics section)
Mostafa Elashmawy
MostafaElashmawy
after checking your other post, I think the problem is :
Mostafa Elashmawy
Thank-you so much! I have been crying about this for hours. You are a life-save. My boyfriend says thank-you too because he cannot help me and it makes him sad when he is helpless.
MostafaElashmawy
You and your boyfriend are welcome.
I hope this also solved your other post about render issue.Smiley Wink
Mostafa Elashmawy
