Wall and roof taking same material
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
908 Aufrufe, 5 Antworten
Hello everyone,
I have been facing a weird problem. When I select roof and apply standing metal seam roof with the roof all the walls of the building also is changing to metal roof. When I apply siding material to wall, the roofs are also getting changed to siding.
Any help will be appreciated.
TIA.
Sheetal
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Edit the Wall Type structure and see which material is assigned to the exterior layer?
Nachricht 3 von 6
You are creating a new material for the standing seam and not just changing the appearance of an existing material that might be used for multiple items right?
Nachricht 4 von 6
als Antwort auf: ToanDN
This helped. The exterior material was same for both wall and roof.
Thank you.
Nachricht 5 von 6
I was just changing the appearance with the same material. That was the problem. Now I created new material.
Thank you.
Nachricht 6 von 6
Thank you.
When you create a new material, make sure to open the Appearance Tab and duplicate the existing Asset or select a different Asset otherwise you will change the existing materials that using the same Asset.
