Wall AND floor/face based family
4 ANTWORTEN 4
Nachricht 1 von 5
1176 Aufrufe, 4 Antworten
I am new to Revit and am wondering if there is there any way to create a family that is BOTH wall and floor/face based?
Ie. I am looking to model a product that always sits within the thickness of a wall (like a window) but is also secured to the underside of a floor slab soffit (like a section of duct work).
Is there anyway to do this? Or will I need to create a wall hosted family and create a parameter for the height that is adjusted to equal the slab height?
Thanks in advance!
4 ANTWORTEN 4
Nachricht 2 von 5
L.Maas
als Antwort auf: Anonymous
No your family is one or the other. Advantage of face based families is that you can put it on walls and floors.
If your issue is to be modelling the same family twice you might consider to create a non hosted family and then nest it in a face based family and nest it in a floor based family.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 5
ennujozlagam
hello, you can start to learn revit HERE and HERE. thanks
Nachricht 4 von 5
Corsten.Au
you can look into
1. Wall Sweep
2. Floor Slab Edge
Corsten
Building Designer
Nachricht 5 von 5
Thanks in advance!
For you specific example I would use a wall based family with a top reference plane to constrain to the slab above in the project.  Keep it simple.
