Hello all;
We have an issue where we are creating existing plan, demo phasing, and new construction. There is a pilaster in a masonry wall. In existing phase the column cleans up with the wall, but in new construction it does not. We have checked all the common issues - materials, top/bottom heights, view template filters, class (structural or architectural), cut profile, to name a few. The only way that they are cleaning it up is in new construction phase they are using a "white color" detail line and drawing over it.
Thanks in advance...
Jleibold
Can you share screenshots for both phases? Is there any new wall in the closed proximity that messing up with the joint?
No walls that are close...
1st image is it looking correctly, 2nd. one does not...
Intriguing. Can you share a file, please?
barthbradley,
Thanks for the reply...
Show All displays the "existing" as half-tone (gray) - which is what we want, but Show Complete is "by category" and will not show up half-tone (gray).
The best approach would be to save a copy of your file (detached, if it is workshared), strip it down to the elements shown in your screenshot, and attach it to your next post.
Hi @Anonymous
It's been a while and I'm checking back to see if you still needed assistance from the community. Please add a screenshot of your issue, and it will help us troubleshoot your issue further.
Looking forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
