I downloaded up to date Vray and Revit software and have finished a model in the program, but when I attempt to render it with Vray the frame buffer window doesn't show my design even though it says it's been rendered...
Here is what I am getting when I try to render it. I have looked at tutorials on youtube on how to use the program but he didn't get this issue like me.
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
… hi @Anonymous
… the main issue here is that you are rendering the wrong image
… first you need to chose the view you want to render
… the current view is the one you will chose and v-ray will be rendering
... you got the wrong one.. if you want to see 3d choose 3d ... and so on
… then take a look at all the V-ray for REVIT tutorials … and follow them
… this quick start series are great
… Intro+to+V-Ray+for+Revit+QuickStart
… or go directly to those forums
… we can be back and forth trying to find all solutions
… but the truth: … it is better and faster if you follow all those tutorials
… you will learn all the basics
… it is easy … just follow the tutorials
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
