which is the best method to get volume of water in a swimming pool, which is having deferent levels? Pool is already done
3d view attached
Hi!
i would recommend to use rooms for this. They can calculate volume.
Did you try to use rooms?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
hi ,
I have tried with room, but its not possible because of the level deference. is it possible by making mass above the pool.
You can create some extra levels and place several rooms and get total volume in schedule.
I believe, It's easier than making mass.
I would make a model in place, forming an extrusion using pick lines. If plan view is not rectangular, I will create void inside this model in place and cut accordingly. You can also give it ocean blue material that will look nice once rendered. It is just 1 min work ![]()
Edit: Added attachment
While using the Room method might work I would opt for @BIM.Consultant model in place solution. With rooms, if you change to a different phase the 'water' will disappear until you copy paste them again. With a model in place mass or generic model, you can see the volume changing on the fly just by grip stretching the water level. Lastly, pool water is a physical element and should be modeled as such.
