I've been using Revit for years, and voids still make me want to toss my computer.
I created a family of fancy millwork, which I imported to my base model and placed against a wall.
I would like to create a void inset that cuts the millwork and the wall (a display monitor).
I've made four different void families (separate and modeled in place), all of which have some issue and basically don't work.
How can I make a void that cuts both the wall and the millwork? And that is adjustable (depth the void cuts into the wall, and basic height and width of the void inset)?
Help please!
Solved by ToanDN. Go to Solution.
An In-Place Modeled Void will only cut System Families - not Loadable Families.
What is the category of your millwork family?
I drop the link of the cuttable family category for Void cut family, check it out and it may help you:
