Void visibility
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
drenL5229
635 Aufrufe, 11 Antworten
Void visibility
I have a problem I don't know how to solve. I am using a void to cut an angle in a line based profile. I want to have my void not visible if the angle is 0 as it would not have to cut anything and I don't want any errors in my family when I do set it to 0.
It is an instance based parameter. I wanted to set it off with an IF statement but I am having errors for "circular..".
Basically, how to turn off the void when I set the angle at 0.
I appreciate your time.
11 ANTWORTEN 11
Nachricht 2 von 12
curtisridenour
als Antwort auf: drenL5229
You should use a yes no visibility parameter. Also you should set a parameter to the angle that has a formulat that never goes to 0 so it does not snap.
_Angle = if(Angle=0,1,Angle)
Nachricht 3 von 12
drenL5229
als Antwort auf: curtisridenour
Actually I want to have the ability to set it at 0 as well, snap, as you said.
So, if(Angle=0, Void (off), Void)
I hope this helps.
Nachricht 4 von 12
curtisridenour
Post your family here. I can take a look.
probably more like this though.
Void = if(Angle =0, 1=0, 1=1)
Nachricht 5 von 12
mhiserZFHXS
You'll need a parameter for you to actually control the angle, and then a parameter that is linked to your voids angle. For the parameter controlling the void, you'll need an equation like :
If (Angle=0, 45, Angle)
This makes sure your angle parameter doesn't break.
Then, for your visibility parameter, have an equation that says:
Angle>0
This will hide your void if the angle is zero, since the voids angle will actually be 45, or whatever number you decide.
Nachricht 6 von 12
drenL5229
Find it attached below.
Thank you!
Nachricht 7 von 12
curtisridenour
see below and attached.
Nachricht 8 von 12
curtisridenour
als Antwort auf: mhiserZFHXS
Angle>0 is a more elegant solution.
Nachricht 9 von 12
mhiserZFHXS
You don't need the if-statement for the visibility parameter. It just needs to be:
Thickened slab angle > 0
Nachricht 10 von 12
You don't need any extra parameter or formula.
Nachricht 11 von 12
drenL5229
als Antwort auf: ToanDN
@ToanDN thank you!
It looks obvious now, so basically put it outside the reference line so that the extrusion has always 4 sides and we don't have to work with triangles, which I did and it made everything more difficult to figure.
Thanks!
Nachricht 12 von 12
Correct.  This is the method I used in older Revit versions, when we didn't have the luxury of the Cut geometry parameter for Void.
