void in a family
hello
i need to put a void around a "box".
the box and the void are in the same family
the box is some MEP component that needs to bo inserted in floors or in the ground
thisfamily that i want to insert have to "hide/cut" with void the support that hosts it
the family is a plumbing fixtures, it's the less worth category i found...
hte void as the same geometry as my box but there is no way when i insert it!!
i insert a void in a generic family with only a void and it works
so i thought that if i change the category of my box from plumbing fixtures to generic ficture the void will be "visible" but not... i see my box but not the void that should cut the ground (in my tests i tried on topography)
have you any idea how to cut the topography, the floor with the box and its void?
Phil
