Void Forms / Void Extrusion
3 ANTWORTEN 3
Nachricht 1 von 4
milton_simpson3FJZF
554 Aufrufe, 3 Antworten
Hello All
I am modelling a container with slots/ holes on each side. I have done successfully on front/back view.
When I try to do a void extrusion on the left/right sides, it appears to show the extrusions shapes but they
are an orange colour, and fails to extrude.
Is it only possible to do one void extrusion per geometry? I have tried several times to no avail. (this model is a family).
Can anyone suggest a solution.
Many thanks
3 ANTWORTEN 3
Nachricht 2 von 4
It seems that the issue you are encountering in Revit stems from being unable to perform multiple void extrusions when creating a family. You can try the following steps to resolve this:
Check Void Intersections: Ensure that your voids do not intersect. In Revit, intersecting two or more voids can lead to such issues.
Verify Extrusion Direction and Position: Check the directions and start/end positions of your void extrusions. Incorrect settings can cause the extrusion to fail.
Merge Voids: Instead of multiple void extrusions, if possible, create a single void and use it to carve out all desired areas. Using a larger void may achieve the same result.
Verify Work Plane Settings: Make sure you have selected the correct work plane for each void extrusion. Incorrect work plane selection can also lead to such issues.
Reload the Family: After making changes, reload the family into the project. Sometimes this can help resolve issues.
Temporarily Hide Other Voids: Start with a single void extrusion first, then try adding the other voids one by one. This can help identify which void is causing the problem.
Nachricht 3 von 4
Orange just indicates that the Voids are unattached. Use the Cut Geometry tool to attach them.
Nachricht 4 von 4
Hi @milton_simpson3FJZF
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
