void extrusion not cutting metric shape
6 ANTWORTEN 6
Nachricht 1 von 7
428 Aufrufe, 6 Antworten
created a metric shape (attaching a pic) and i want to void extrude- make a hole somewhere specific(orange rectangle).
when i need to cut the void from the mass, it doesn't let me pick the mass, let's me pick walls and floors but not the mass.
why?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Edit the Mass itself an create a Void Form intersecting the Solid Form.
just to be clear, Void Form is modeled the same environment (e.g. same family) as the Solid Form.
Nachricht 3 von 7
als Antwort auf: barthbradley
in the mass itself i don't know the specific place of the void that i need.
when i upload the whole mass into the whole project, there are additional items that are built there and because of them i know where to place the void.
Nachricht 4 von 7
Are you applying Walls/Roofs to Mass Faces and want to cut those Walls/Roofs.  You can do that by Model In-Pace Void and then use Cut Geometry to cut the Void Geometry out of the Wall/Roof before closing out of In-Place Modeling mode.
Nachricht 5 von 7
that's exactly what i'm trying to do but it's not walls or roofs. it's a metric shape i brought into another file.
and when i try to cut geometry, it allows me only to pick items that are walls/ floors and not the mass but i need to cut the mass.
Nachricht 6 von 7
Metric or Imperial doesn't matter. What is the "shape"? Is it a Mass Family? To cut the Mass Family, you need to open and edit the Family and use a Void Form to "cut" the Solid Form INSIDE the Family.
Maybe I can help you better if you post the file for me to examine.
Nachricht 7 von 7
family 19 is the mass itself
option 2 is my project+mass inside
@barthbradley  i missed your last message somehow
