I'm having a little problem cutting a roof. I have used the dormer to make the cut but the thing is that I like the window to be higher. I like to make a cut where the red line is but only where the window are?
Thank you / Rickard
Rickard,
Could you post a small model for me to try this? You can add extra cuts to the roof by making custom voids that are defined by the cutout made by the window on the wall.
Also, there is a question of what happens to the wall-roof intersection right under the window. From your drawing it seems you want the roof rafters to be notched to make room for the window. A custom void cut could achieve that.
Use a void to make the cut you need.
