Hello all,
I have a question about a my family file.
I'm working with Revit 2017, I have designed two solids but I can see only one.
I don't understand why.
Please, can you help me?
Thank you so much.
Bye.
Antonio
Solved by ToanDN. Go to Solution.
The door is completely cut by a void. See attached I stretched the void down and it shows.
For your family, I would create the void(s) first, cut them to the host wall to create the opening, then create the door and frame elements. See revised file and screenshots of the door family and when it placed in a wall in project.
Thank you for your help.
There are two voids (one on this, the biggest, disappears) and a "window".
I have tried to modify the biggest void, but now I can't see the window.
Sorry, but I'm a beginner.
Thank you again.
Bye.
Antonio
