Hi everyone,
This is a new Project, no view templates or overrides applied, just the levels, grids and floors
I placed one floor on the ground Level 0 then copied to clipboard and pasted aligned to selected Levels 1 & 2 (I have 1 more Level 3 which is a not a building Level and has no plans)
The floor on Level 1 Looks ok but the floor on Level 2 does not look ok!...They Show in different Colors! Only in plan views
In 3D (also shaded view) they look the same Color, also in section...I tried changing the render appearance to a different Color but that made it even worse!! light colors do not even Show on Level 2!
....I added a new Level above Level 2...same thing
....I added a new Level between Level 2 and 1 ... same thing
Only way I can see the colors is in Consistent Colors or render mode Or if I use really dark Colors in Appearance Settings.. I am still not sure how the other floors of the same type showing different!! If it is graphics Problem it should apply to all..or not?
Edit using revit 2016 update 6
Any Ideas what is wrong!!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous try to untick "use hardware acceleration" from options > graphics and see if helps. or try to updates your graphics card driver to the latest. thanks
@ennujozlagam I have already tried that, unchecked Hardware accel, closed Revit, restarted pc always same Thing
I tried more testing in a new Project in an attempt to get it to work...So
It seems to happen in a fixed rythem!!!
And so on ...the more I add Levels it follows same rythem!
I tried not to copy paste...I placed the floors Level by Level and same issue!!!
@Anonymous hello, try to update your graphics card driver to the latest. i tried to replicate what you have done and i didn't experienced what you had experienced. check if we have the same build Revit 2016.thanks
I think this is related to sun and light settings in your view, Just follow below steps:
1. Go to Graphic display options in view Properties
2. go to Lighting.
3. Sun setting: select "Lighting"
It's just a simple solution
