Visual Style like editing an Design Option
Martin_TAS
Martin_TAS
When editing a Design Option, the Main Model became almost washed out from color. We want this effect for the Existing Phase in a particularly view. We've tried with Phase Graphic Override and also with a filter. But in both cases Halftone only applied to lines, not to Color Patterns (in Shaded View).
We don't want to find the solution in editing materials. Is it possible to get the Visual style show in the attached image? Tried Google on all keywords I could imagine but couldn't find an answer.
Thanks!
Martin_TAS
My problem is not with Design Options. I only mention them because when editing an Design Option, Revit shows the visual style we like.
What we want is the Existing Phase almost white with a little bit of color and the New Phase normale colored. When using an Halftone setting, colors are not changed.
Post your RVT here so I can see what I would need to override in the View to make that effect. It may take a combination of overrides to get there.  It may take deactivating some as well, such as the Phase Filter Graphic Override.  There is an override hierarchy to workaround.
Martin_TAS
I made an simple project file with a existing and new phase. The project-file where we want the effect I cannot share. In a legend there's an example of the effect like to have: soft colors for the existing phase and normale colors for the new construction.
Phase Filter Graphic and normal Filter I tried but 'halftone' seems to effect only lines.
