The 3d Model in Site view is invisible. In all other Floor plans it is ok. Range in Properties browser is set to <unlimited> top& bottom. Also, ell elements of the Model are set to be visible. What might be the reason for that invisibility as Site view should show all existing level plans ?
Phase filter set to <none> or <show all> , or <show complete> - same situation. <Crop region visible> is on and it contains the Model area, still no change
Have you checked it hasn't been hidden in view by mistake?
(click on the little "lamp" icon at the bottom of your view to make it visible. If apprearing in pink, you can select it and unse the options in the ribbon to make it visible)
Any template for your view?
François
Francois-Gabriel Perraudin
BIM management and coaching
1-The 3D model could be hidden, click the reveal hidden elements button.
2-If your model is a linked rvt file than check your visibility settings for linked files
if your model is the attached dwg file it might cause the problem, I suggest you check your visibility settings for the main file and for the linked file.
I am curious did you solve the problem. If not it could be about view range settings or depth clipping in the properties window of the view.
