Visibilty/Graphic Overrides for Familys
6 ANTWORTEN 6
Nachricht 1 von 7
277 Aufrufe, 6 Antworten
Why isn't there an extra tab for een override for Family's? Whe have to make filters to switch them off, and if there is an extra tab whe can switch them off more easily.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Select a family, right click and pick Select all instances in view, the Override, or Hide. Same result.
Nachricht 3 von 7
artejon
Revit Ideas seems to be a better place for that.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Nachricht 4 von 7
chrisplyler
Another way you might find useful is to look in the Project Browser. Expand the Families hierarchy, expand a category, right click on a specific family type, and choose "Select all instances..." from the contextual menu. Then you can override them all by-element.
Nachricht 5 von 7
chrisplyler
als Antwort auf: chrisplyler
Although it does kind of make sense to imagine - not another tab necessarily - but instead that the categories be expandable to list loaded families underneath them in a hierarchy, and that the families be further expandable to list the used types underneath them.
In this way we could just drill down to create more specific overrides than just complete categories. It's an interesting idea.
Nachricht 6 von 7
You understand me! I hope this solution will be in a next generation of Revit.
Nachricht 7 von 7
chrisplyler
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
Um...yes...so do I.
Another method, of course, is to make a view filter that picks up the families you wish to override, apply that view filter to your view, and set up the desired overrides using it.
