visibility
This widget could not be displayed.
visibility
There are several items on my drawing that appear grayed out on the 3rd level plan, but don't appear at all on the 2nd level where they actually exist. How do I make them visible on the correct level and not visible on the wrong leve?
www.TechRoom.bg
If i understand you problem right, you must check your view range of level 2 and 3. Also you can uncheck underlay option from level 3.
If you need more help about this post reply
Good luck
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
