I have issues with line weights. For example, window projection lines can be changed form VG - Window but as you can see from my screencast the contour or frame of the window remain quite thick.. how do we change it, where I can find in VISIBILITY Settings ? Thanks
You can look under Object Styles to see what lineweight settings are used.
However if you mean that lines are too thick on screen (versus printed), then you can:
- set a greater scale of a view
- turn on Thin Lines under Ribbon>View?Graphics.
