Hello I got this error when I try to draw structural column
None of the created elements are visible in Floor Plan: 01 Ground Floor View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
Knowing that I checked all the books inside this tab
( Modle Categories/ Annotation Categories/ Analytical Model Categories/ Imported Categories )
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
My guess is that it's not within the view range. Change column so it intersects view range, or visa versa.
ps. are you aware that structural columns typically have a negative height value on placement?
@Anonymous hello, when you drag your structural column use height instead of depth (see screenshot below). or check your view range and view template if anything is assigned to that view. thanks
