Visibility Problem of a Model Pattern in Cameraview
2 ANTWORTEN 2
Nachricht 1 von 3
krueger
351 Aufrufe, 2 Antworten
Hello!
We've run into a problem concerning the visibility of a Model Pattern in one of our Cameraviews.
The Project was created in RVT16 and was recently updated to RVT18, however the problem existed back in 16 aswell.
The Pattern mimics a certain brick called ClickBrick (not the Knockoff Lego one though) with height: 10cm and width 24cm.
Its a selfmade model pattern which I applied to the outer material of our exterior wall.
However as you can tell from the screens I've attached it only shows in our view when zoomed in, which we obviously dont want.
We have limited space on our sheet and dont want to make the crop even bigger and setting the pattern to a more grey color only made our material appear even lighter. Applying different sun settings didnt help either.
So my question is: does anyone have any suggestions what else to try?
Any help is appreciated!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: krueger
Did you create the texture of the brick from an image or from Revit procedural tile?  And to be fair, if you looked at a building from such distance, you wouldn't see the bricks very clearly either.
Nachricht 3 von 3
krueger
als Antwort auf: ToanDN
Sorry I've forgot to mention that we are not allowed to use any renderings or realistic images in this project so its just a surface pattern.
Your point is valid tho, but the facade is kinda important for this project so we wanted to show it in this view aswell.
