Good afternoon. it's been a while I don't post a question here.
I am making a project in my nation, Colombia, called "Tukahnes Condominio Campestre" [see draft render below - remember that I am a quite beginner 😉 ]
I made my title block and I want to use the same one for the Cover sheet, floor plans, elevations, etc.
Since I want to use this for future projects I don't want to drag again the same information, Notes, legends, key notes, etc. That's why I created a parametric one which allows user to hide and unhide certain information: for example I don't need floor plan notes in my cover sheet, I select the title block, I go to edit type and uncheck floor plan notes, north arrow, I check only information pertaining to cover sheet like symbols, consultants directory, etc and voila, it's done. BUT as soon as I go to my floor plan sheet, containing the same title block, the information pertaining to floor plan is gone and cover sheet information is showing up.... I'd like to have the same title block where I can control visibility of specific information individually.
I hope that I can be understood, English is not my primary language... but this is essentially the full idea. any suggestions please?
Thank you.
