Hello. I am editing the floor plans and building schedules and I am trying to create a new room using the room separator command, but every time I create a separator, it gives me this message:
"None of the created elements are visible in Floor Plan: FP Level 3 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
I have tried a bunch of things, even checking every box in the visibility graphics menu but I still get this message and I am unable to see the separator I create nor place a room tag. Keep in mind I inherited these drawings as they were drawn by another consulting firm so I am trying to find my way through their work. Any help is much appreciated.
Room separation lines are a subcategory under "Lines". Its probably unchecked.
Also, the separators are still there (all of the ones you've placed) so they should still work, though you may want to go in and clean up all of the duplicates you may have placed.
Thank you for helping. Unfortunately, it is still not working. When I try to place a room, it is bounded by other lines I cannot see. I am trying to make the room cover the entire of the white box space. That space used to be individual cubicles (rooms) I all deleted to make a single a room, hence the white space. Any idea how I can go about this?
Because you still have room bounding elements there. They either hidden via VG, or obscure by a floor finish (those hints should be enough for you to find them). If not, share the file here.
