It would be great if the default keyboard shortcut for Visibility/Graphics Overrides worked for schedule views like it does for views and sheets.
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
There is no Visibility/Graphics overrides dialog while a schedule view is active, it's not a view property/option. Keyboard Shortcuts will work (and so would VG or VV if there was a dialog for schedules) if we move the cursor up to the ribbon while a schedule view is active. While the cursor is within the view of a schedule Revit assumes you're going to type information into the schedule.
Steve Stafford
@SteveKStafford, not entirely true.
The Visibility Overrides is available to schedules when design options are created.
Look this may seem small fry (and it is), but when ploughing through multiple views/schedules to associate various design options (some times many), it would be good if the keyboard shortcut consistently worked.
On the off-chance that this turned out to be a 'low-hanging-fruit' for the Autodesk developers.....
@SteveKStafford, oops I didn't read your reply properly. ![]()
Shortcut working fine. Ignore me.
