Visibility / Graphic overrides: Documentation process workflow
4 ANTWORTEN 4
Nachricht 1 von 5
XXalessio.amodioXX
344 Aufrufe, 4 Antworten
Hi all,
During our firm BIM workflow we usually stuck in Documentation process. It is very hard to submit sheets that must comply with country regolamentaion / law.
To reproduce a good visibility of elements visualization I usually filter/override them trhough these following steps:
1. Globally Manage Object Style (Categories and Sub-Categories)
2. VG Workset > 2.2 Model Ctaegories > 2.3 if necessary prepare a Filter
3. Modify Line work > 3.1 if necessary Detail Line, Detail Item.
4. Create View Template (From view)
What is your workflow? Have you even encountered the issue above?
4 ANTWORTEN 4
Nachricht 2 von 5
RobDraw
als Antwort auf: XXalessio.amodioXX
What exactly is the "hard" part for you? What regulations/laws are you referring to/trying to follow?
Documentation and visibility are not always directly related so your statements are a bit confusing.
IMHO, take workset out of that list entirely. That's bringing in a user assigned property and possibility for erros way too early.
Rob
Nachricht 3 von 5
Yes, I'm curious to know more specifics as well.  Are you are talking about digital submittals?
Nachricht 4 von 5
XXalessio.amodioXX
als Antwort auf: RobDraw
@barthbradley @RobDraw E.g. Rapresentation of stairs (I have encountered many issue to show stairs according to Czech law).
There are may others I do not want bother you to list.
My issue is to prepare a model in order to achieve right Documentation sheets (Trying not to use to many override/line work/2D line)
I want to know, by your experience, wich is the workflow you follow.
I know it is quite wide topic, but I am seeking of tips.
Nachricht 5 von 5
RobDraw
It's impossible to give any suggestions without examples. Show us what you have and give an example of what you need?
Rob
