Visibility error
Visibility error
PrathapSekar
Visibility error
PrathapSekar
Hi Masters...
We are working in a central work-sharing Revit Model, on that we have placed wall tags for a wall. In my system the tag text going out of border, while in others system its remains inside the box.
We are working on Revit 2017, and I Just upgraded to 2017.2.1. Please help me to resolve this error. Thanks In advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
L.Maas
When working with a central file make sure that everybody is using the same Revit version to avoid such issues
Louis
Please mention Revit version, especially when uploading Revit files.
Karol_Piroska
Maybe you can check if you have installed the required font or tag with correct text width factor (as the text width factor appears different)
