Visibility controls for individual point clouds in linked files
10 ANTWORTEN 10
Nachricht 1 von 11
kelly.cone
630 Aufrufe, 10 Antworten
If you have multiple point clouds (RCPs) linked into one file, and then link that project (RVT) into another project, you lose the ability to turn off individual point clouds in the host project. For example, if I have both Architectural and Structural Revit files, and I have Scans of Area A and Scans of Area B (two different RCPs) loaded into both my Architectural and Structural Revit files, and I link the Structural file into the Architectural file... if I open a view and turn on point clouds, but then turn off "Scans of Area B"; it will turn off those scans in the host file, but they'll still be visible on the screen in the linked file. So, you basically lose the ability to control the visibility of individual scan files if you have linked Revit files. It doesn't matter if you only have one because the global check-box works as intended.
Pretty sure I'll need to go to VG, set the links to display by "Linked View" and then set up linked views to match in each linked Revit file (I have 4 total, so it's a bit of a PITA). Hoping someone knows something I don't. Also, @thefactory - if you're watching please file this as a bug. :leicht_lächelndes_Gesicht: "Files" should act like "categories" in the model tab, and scans and regions should act like subcategories. So, if I turn off a file in the view in the host revit file, it should hide it even if it is loaded into the linked revit file. :leicht_lächelndes_Gesicht:
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: kelly.cone
What about putting the PCs in their own RVTs and Linking the PC RVTs into the Projects?
Nachricht 3 von 11
kelly.cone
That is another solution, as is using design options, etc... Of course, then I have to control the visibility by linked files instead of by the point clouds, and I lose control of individual scan / region visibility. So, this is probably the worst option of the three.
Nachricht 4 von 11
kelly.cone
Of course, as I just remembered, this doesn't work for perspective views. Boo.
Nachricht 5 von 11
Are you not able to TAB-Select the Point Cloud in the Link and Hide in View: Elements?
Nachricht 6 von 11
What doesn't work in Perspective Views?
Nachricht 7 von 11
kelly.cone
als Antwort auf: barthbradley
Across a couple hundred views? :lächelndes_Gesicht_mit_lächelnden_Augen: No thanks. LOL. Needing a scalable solution. Probably have to put them on a workset and hide that workset in all linked files. That way, only the host file’s point cloud settings have any impact on the view. Testing that now. Hate using worksets that way, but linked view not working for perspective views is a killer. So…
Nachricht 8 von 11
Odd. What version of Revit are you using?
Nachricht 9 von 11
kelly.cone
Perspective Views don't let you set linked files to use linked views (still don't in 2021). So, you can't use what I was originally doing for perspective views. Bummer...
Nachricht 10 von 11
Ah! Yes.
Good luck.  BTW, Welcome to the Forum!
Nachricht 11 von 11
kelly.cone
Thanks! Apparently my old "existence" on here expired. LOL. I'm re-born! :Gesicht_mit_Freudentränen:
