Visailabillty of hatch
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
glkirk
739 Aufrufe, 4 Antworten
Does anyone know why I get the see thru of thi hatch pattern in the program and after converting to pdf?
Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
Jason_S
als Antwort auf: glkirk
By chance did "Overwrite Graphics in View" and Transparency get turned on in your view for that element or wall?
Does it show transparent in the elevation?
Nachricht 3 von 5
syman2000
Check and see if the material has 100% transparency. Set it to 0 so it will not see thru.
Nachricht 4 von 5
glkirk
als Antwort auf: syman2000
Gosh you were right and I thought I looked into that!
It was not in over ride graphics in view
Thank you both!
Does anyone know where I can get a pat file a bit closer to the "Stacked stone" that is so popular now?
Thanks again.
Nachricht 5 von 5
hmunsell
i was going to say your Thin Line (TL) was turned on in your view, that will effect how you see the linework in your view. but if @syman2000  worked, that's great too. don't forget to mark it as the solution :-)....
Howard Munsell
