Nachricht 1 von 3
jfjacques
188 Aufrufe, 2 Antworten
Views
Might be a feature request.
Is there a way to lock a hotkey onto a view? I know I can for create a hotkey to create a new 3d view or a new plan view, but say I want to go to a specific plan view, is there a way of locking a key onto it so I can just click and go?
Most other 3d modelers have some form of this.  Would be a huge timesaver.
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: jfjacques
No there is not. I just use other methods to get to my views. Depending on the project I might use
-Use Find in the project browser.
-Make use of naming the views (e.g starting with underscore floats them to the top)
-Use browser organisation to group most relevant views together
You might check in the IDEAS section if there is a similar idea and vote for it, otherwise create one
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
Corsten.Au
View ReferenceView Reference
Hi..Instead.. You can PLACE View Reference on any view , linked to any view...
so For Example
Part A of plan can have a " View Reference Part B" clicking that view reference will
take you to Part B.. and
similarly " View Reference Part A" can be placed on Part B Plan view...
View Referencei is like a link to any view, Customise it for your easy use else use
Example : Reference Text Plan, elevation , Section written in tags... else use
the default reference tag of View number / Sheet number  Ex 1/A102 etc
Best luck..
Corsten
Building Designer
