VIEWS
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
DavidRaines
519 Aufrufe, 7 Antworten
VIEWS
Is there a way to go back to default on the views or remove them from the drawing?
David
7 ANTWORTEN 7
Nachricht 2 von 8
Sahay_R
als Antwort auf: DavidRaines
In the Project Browser - you can right click and delete views.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 8
What do you mean by "Default"?
Nachricht 4 von 8
If you are talking about "3D Views"....rename the current one to something else, then the next time you click 3D view it will start from the default orientation and you can delete the old one.
Nachricht 5 von 8
ennujozlagam
@DavidRaines   Hello are you referring to Browser Organization.just right click Views. Please see attached screenshot. Thanks
OMG, we are all guessing?
Nachricht 6 von 8
als Antwort auf: ennujozlagam
OMG! Let me try one...
Go to View Tab: Plan View: Floor Plan: uncheck "Do not duplicate existing views": Click on the level name you want to re-create. A new view will be created for that level using the OOTB "Default" view template settings.
How'd I do?
Nachricht 7 von 8
to remove from a drawing if you mean from the sheet .. just select and delete ..
kindly clarify what is needed...
and what do you mean by (default)...
Nachricht 8 von 8
DavidRaines
als Antwort auf: barthbradley
Thank You
