Views with identical properties, only one appears on key plan
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
ct_studio
360 Aufrufe, 7 Antworten
Both are set to display at scales coarser than the key plan. The key plan (and its independents) uses a filter to only show view markers that are on the given sheet. It is showing multiple sections as intended on other sheets but on this sheet, I can only see one of two sections that should appear. Nothing is shown when I reveal hidden.
7 ANTWORTEN 7
Nachricht 2 von 8
ct_studio
als Antwort auf: ct_studio
I recreated these using duplicated views rather than dependents when I remembered I need to apply different filters to each view. Still having the issue where only 1 of 2 sections appears on the affected key plan.
Nachricht 3 von 8
Check [Hide at scale coarser than] parameter of the section views.
Nachricht 4 von 8
ct_studio
als Antwort auf: ToanDN
Both are set to hide at a scale coarser than the view scale
Nachricht 5 von 8
ct_studio
Nachricht 6 von 8
ct_studio
When I place a new view on the sheet, it appears on the legend without issue. It's just the existing section that doesn't want to appear, even when I duplicate the view and try placing it again:
Nachricht 7 von 8
ct_studio
Ah.. it appears when I drag the view extents up. Is there a way to do this without unnecessarily extending the view extents?
Nachricht 8 von 8
ct_studio
Solved by extending view depth to unlimited and making other changes in view template to hide stuff on the ground that appears now.
