Revit won't allow me to open certain views and sheets in m file, while others are able to be opened no problem. I get this error message (see photo attached). Originally I thought it was my graphics card, but everything else on my computer works fine, it is only Revit causing issues. Does anyone have a fix to this?
Any idea if there is anything unique about those views? are they Rendered, Shaded, Shadowed, imported images. etc....
I would also consider checking and seeing if there is an update available for your graphics card, it couldn't hurt.
Howard Munsell
Have you tried other suggestions here?
The only thing I can think of in one of the views is that there is a color fill and color fill legend... which I get an error message that says it is unable to calculate.
Graphics card is good and works everywhere else, up-to-date and uninstalled/reinstalled.
@eluthrin wrote:
The only thing other thing I notice is that Revit will crash when I try to click, drag and move a wall or design element.
Is this only happening in one specific model or is it happening in other models as well? Would you be able to share your model with us?
Howard Munsell
copy the model, delete the client information out of the model? send us the copy....
do you have an IT department that may have pushed out a security update or something?
do you have the same issue on another PC in your office?
Howard Munsell
If you can't post the file here, then open a Support Case with Autodesk through your Account Portal.
