A pop-up appears when opening file "SHT.RVT" :"file missing some important elements" so I searched for last local file , open it and sync to Central but after syncing ,views disappeared !
This time I detached local file from central , save it with new name and made it central . and this working ![]()
Now file "ID-FUR .rvt " has the same problem and when syncing from the last local file to Central ,model elements disappear!
after sync from last local file to Central
I recommend doing a new fresh copy of the models with Audit.
Many reasons can impact or result in this.
As @Ryan_GormanKT36T said all these questions and much more may impact our answer.
but start from the easy solution i mentioned first
You found a post helpful? Feel free to give it a like!
Your question got successfully answered? Click the 'Mark as Solution' button.
alt="Autodesk Expert Elite" style="width: 150px; display: block; margin-bottom: 10px;" >
Mahmoud Zeidan
BIM Manager / Mechanical Engineer
