Viewports issue...
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
arsham
347 Aufrufe, 6 Antworten
Viewports issue...
hi, i have some viewport types that are used in my revit template, but there is one that i havent used and it came into my template file by mistake, someone copied something....
anyways, i have not used this type for any views and yet it doesnt appear in the purge window. i used dynamo to delete it, but it deletes some drafting views, the funny part is that those drafting views are using another type, any idea whats going on? thanks
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: arsham
The default Viewport1 type cannot be purged even if it was renamed to
something else.
Nachricht 3 von 7
arsham
thats not it, its called "section 1", in my backup files from few days ago, this viewport wasnt there.
Nachricht 4 von 7
Alfredo_Medina
Maybe somebody renamed "Viewport1" as "Section 1".
Nachricht 5 von 7
arsham
read one post above...
Nachricht 6 von 7
arsham
someone imported drafting views from another file which had this viewport in it, without removing it and purging the file.
the funny part is that i dont even have any views on the sheet with this viewport, and when i delete it with dynamo, it deletes some views.
i removed all the views from the sheets, but they still get deleted when i run dynamo.
so i just deleted all those views, and the viewport and reimporting them properly this time.
sometimes even revit gets tired of its users....
Nachricht 7 von 7
arsham
solution is to rename the default viewport in those drafting files to one of the type in the main file and then import the drafting view.
thanks everyone.
