Viewport Saved Position not aligning
jasonswolfe
Message 1 of 1
jasonswolfe
Hi -
I just noticed an issue in Revit 2026 which I believe is a bug.  I've been using the new Saved Position feature and noticed that one of my views was out of place.  In that case it was very subtle (but unfortunately it was in my template, so every project based on the template was affected).  I was able to fix the issue by deleting the offending view and making it new.  Duplicating the view did not do anything.
I now have a second file that is misbehaving, and this time the resulting offset puts the drawings several feet off of the sheet (which in some ways is better because it's obvious).  Recreating the view that was different than the rest did not fix the issue in this case.  I had to recreate all of the views to fix the issue.  Luckily they were just SD plans, so not much was lost.  Otherwise I would have just forgone using the Saved Position feature and gone back to manually aligning the views between sheets.
I haven't been able to recreate the issue, so I'm not sure what's causing it.  I thought it may have been connected to mirroring the project with scope boxes included, but I tried that on a test file with the same conditions, and it worked fine.
I'll follow up if I can determine what's causing the issue, but just wanted to post this up in case others are having similar issues.
Jason
Replies (0)
