Viewport Rotation
5 ANTWORTEN 5
Nachricht 1 von 6
RickLight
458 Aufrufe, 5 Antworten
Viewport Rotation
I want to rotate a viewport and not have the title bar rotate as well.
Being new to Revit I went to Help and got this:
https://help.autodesk.com/view/RVTLT/2019/ENU/?guid=GUID-10044F8E-7DC4-46C8-9AF5-B7E0FB8AD751
Well it's wrong! What now??
And how to I edit these
Rick
Revit LT newbie
Win10 workstation laptop
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: RickLight
You can create a view title family that rotated 90 degree.
Or you can activate the view, turn on the view crop region and rotate it instead of rotating the viewport on sheet.  If the view is a section or elevation, you need to draw a call-out to create a detail view, then do the above to that detail view.
Nachricht 3 von 6
RickLight
als Antwort auf: ToanDN
I tried the crop method and it didn't work.
The crop rotated, and showed a different view of the unrelated model.
The family you're talking about, is that an annotation family, or are you modifying the existing?
Rick
Revit LT newbie
Nachricht 4 von 6
It works if done properly. See screenshot example.
Nachricht 5 von 6
Repeating myself here: "If the view is a section or an elevation, you need to draw a call-out to create a detail view of that section/elevation, then open the detail view and rotate the view crop region."
Nachricht 6 von 6
RickLight
Well, it took me a while to read up on a few topics and make sense. But I got there.
As you say, there are a few more steps for sections, and even a few more than you noted. The crop has to be reshaped after rotation, and the view details completely reset.
Thanks!
Rick
Revit LT newbie
