I have read many posts but it still (maybe) no solution.
I have a few different viewport types to change depending on the project\use - Title only, Title + scale, title + scale + reference. Can one of these be set as the default for all new viewports that are created. Yes I can select the viewport and change the type but surely there is a way to select the dafault ?
Edit the type of a viewport, instead of using the dropdown.
I can get there by saving a family when the TYPE I want to be the default is the current one shown. However, if the family has already been loaded into the Project, it won't change the default. I have to delete the family from the Project Browser and load it again.
Same thing happens with Parameter Order/Grouping shown in the Properties of the family. If I reorder and regroup Parameters in the family, the change won't be reflected in the Project unless I delete the family from the Project Browser and load it again. It's been a frustration of mine for years.
