Good afternoon, I´ve just installed Revit 2024 and viewport does not allow to be enlarged/stretched
any suggestions please?
thanks.
Gelöst! Gehe zur Lösung
Gelöst von RSomppi. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
- Is the view on sheet? if so, did you activate the view and turn on its crop region?
- Is a scope box assigned to the view? If so, change it to None. or open another uncropped view and resize the scope box.
The bottom line is nothing changed between 2024 and any other versions in this regard.
Viewport size cannot be edited directly. They are automatically set to the extents of the view.
@ToanDN , yes it did work, thanks a lot
