Viewing layers of the first floor wall construction from an upper level?
ejowalter
ejowalter
I am attempting to layout some framing components in the attic of a one story house and would really benefit from being able to see the wall layers of the first floor. Trouble is I don't completely have a handle on the viewing range settings for something like that or how to turn on that level of detail for a lower layer.
Can you see anything blatantly obvious that I have wrong in my settings?
BTW - These are 8ft ceilings.
Accepted solutions (3)
Why not use View Underlay to assist you?
Regarding getting a handle on View Range, check this link out - it's pretty good:
About the View Range | Revit Products 2019 | Autodesk Knowledge Network
kjskoog
In your Properties in the Underlay section, change your Range Base Level to First Floor.
Kory Skoog
PM/BIM Manager
ejowalter
Underlay definitely helped. Is there any way to turn up the level of detail so I can see the wall layers on the first floor?
Create Parts from Walls.
ejowalter
That did it. Thanks again.
