Do you have any reccomendations for 3d Viewing platforms/ engines. I am trying to check out "Unity" but redoing the materials is a bummer.
Do you know if there are any "live walk through" viewing engines that the materials from Revit come through?
We have trade shows in 4 weeks. Our 3d virtual reality goggles won't be here until June or so. So we are starting with a flat screen approach but will transition to Virtual Reality.
We are nervous about choosing the proper environment. Any help you can lend is appriciated.
Thank You
Nardo
hi, you can try this ? thanks
I've never tried this. But Autodesk has Stingray that probably can work well.
http://www.autodesk.com/products/stingray/overview
Cheers,
Edwin Prakoso
hi, you can try Autodesk Showcase more materials can apply. hope it helps. thanks
Like I said, I've never tried it myself.
You can try their tutorial series on YouTube.This is the first one: https://youtu.be/iccOOOrc8m0
Cheers,
Edwin Prakoso
with revit & stingray workflow there is a go between for the products called Project Expo which is in beta right now
http://projectexpo.autodesk.com/#
DarrenP
To echo some of the above, you could try Autodesk Showcase, Navisworks, or the Stingray/Expo beta.
Katie
we are trying a variety of environments. Since we already have Navisworks, I would like to know more about what you are recomending. We have the Building Design Suite, with Revit. I seem to only have Showcase in 2014. Not sure whay I only have that year.
Please post links to tutorials and whitepapers that describe the work flow that you are recomending with Showcase and Naviworks.
Thank You
Nardo
here are program include in BDSP. And stingray is another subscription.
For Showcase
For Navisworks
@Anonymous - necroposting on multiple threads for advertising is considered, at the very least, bad form.
