I have three simple walls and a door with the 'default' view range:
I also have a beam across which you cannot see in the floorplan:
I'd like to see the beam in the floorplan but I'd also like the door cut to show correctly too...
If I raise the top and cut plane above level 2 I can see the beam but the door doesn't show "correctly cut" as the wall above it is visible.
So what is the correct way to view bot the door cut and the beam? Can this be done and is it the correct way to represent these details on a floorplan?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Use the ol' Invisible Line Trick.
Several ways, each has its pros and cons:
You can also use a plan region to set a different view depth/cut height for part of the view.
you can have a look at this article you fully understand the theory of revit view range :
https://bimandbeam.com/2022/01/revit-view-range-html/
