When clicking on a new view angle using ViewCube, I like to disable "fit-to-view on view change" in the ViewCube options box. This stops Revit zooming out and resizing the view every time I make a view change.
I have keyboard shortcuts assigned for the ViewCube views "orientate front", back, left right.. and when using keyboard shortcuts, it still does a fit-to-view on view change, even when clicking on the view cube works as expected. Same behavior applies to "use animated transition when switching views".
Anyone know if there is a way to change this behavior? thanks!
thanks ToanDN.. yes that works, when using the ViewCube with a mouse click.. but it does not work when you use the keyboard shortcuts assigned to ViewCube. Same thing happens with "use animated transition"...
As its title says, the option is only available when clicking on Cube...there is no option that extends it to short cuts.
Try your luck on the Ideas forum if the idea is not already there
