hi.in the middle of revit there are some lines wich define the view of floor plan.how can i extend it or remove it so i can use whole window?
Is it coming from a CAD Import? If so, find out what layer it's on and turn that layer OFF in the View via VGOs.
The black solid line?, if you select it, what type of category is it (see properties panel)
Select it and edit its visibility here:
Did you like this post? Don't forget to like and accept as solution!
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
