i think there is glitch as it happens with my model several times a day that aview of a specific level zooms in miles away from the co ords where the moel is and i find no way of bringing it back other than deleting that view and getting a new one. can you sort this out as it happens many times a day
Gelöst! Gehe zur Lösung
Gelöst von Corsten.Au. Gehe zur Lösung
Make sure that there is no linked CAD file in that view.
this happens when you link an unclean CAD file.
before linking the cad file, better to take only what you need to a separate file and put all the drawing near the cad 0,0 then link it to Revit.
Mostafa Elashmawy
@Anonymous: Does this happen when you press Zoom Extents? If so, you got an element "out there" somewhere. Out of curiosity, how far is your model from the internal origin?
First thing is to clean up any linked CAD files..
so that in CAD file when you zoom extent, it shows up correctly..
Try not to import CAD, but LINK them..so that you can turn them off whenever you want. and
unload it when not required..
and check for any elements which are far away...
East way out is to use " SCOPE Box " for
PLAN
ELEVATIONS
SECTIONs
and Zoom extent keeping the view CROPPED...
for 3D, you may switch off " Imported Categories " to get rid of any CAD elements..
