View Titles Dissappear
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
steve
2001 Aufrufe, 9 Antworten
At some point (not sure when), the view titles throughout a project stopped displaying on Sheets. Zoom-all or Zoom-extents does not reveal them off the page somewhere.   Annotation>view titles is checked (on).    Other projects display titles.  I have shut down / restarted.    in the title blocks properties, nothing is "off".  Everything is "on" in VP / model categories and VP/ annotation categories.   the view is not a template view.     Another project I open, view titles display
What controls this and how do i get the view titles back to displaying?
9 ANTWORTEN 9
Nachricht 2 von 10
WEC17
als Antwort auf: steve
I had this happen to me one time all I did was delete you view  from you Sheet and drag it in again and see if it works.
Nachricht 3 von 10
Strange. Maybe updating will resolve.  Could be an add-in too.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
Nachricht 4 von 10
steve
als Antwort auf: WEC17
thanks,  tried that... no go.   View tiles disappeared from all sheets, all views.
Nachricht 5 von 10
steve
disabling add-ins:  Doesn't seem to be related.   All sheet titles are displaying in other projects, with the same set of add-ins.  r2019.    I should/would update to 2021.    But it's a model linked into a site plan with other models linked into that site plan... all linked to Lumion and I just don't want to deal with a busy work fix.
Nachricht 6 von 10
Edit the viewport type and make sure Show Title = Yes.
Nachricht 7 von 10
2019.2.2
Nachricht 8 von 10
steve
Solved - select the viewport in sheet view.... EDIT TYPE > SHOW TITLE (CHECK YES)
Nachricht 9 von 10
@ToanDNgot there a week ago. Message 6.  :zwinkerndes_Gesicht:
Nachricht 10 von 10
RobDraw
Why are you giving yourself credit for a solution provided by someone else?
Rob
