View Title Text Parameters
ccasserly27WWJ
ccasserly27WWJ
Hello -
Currently the firm I'm working for is switching over to Revit from AutoCAD and we wanted to keep our standards as similar as possible. I wanted to remake our drawing title in Revit which I thought would be relatively simple. The issue I'm having is the gray bar is suppose to adjust based on the length of the title above.  I've tried to set a basic instance parameter, but these don't seem to work for drawing titles. Is there anyway to link the bar's length to the text length above? Or even link it to the extension line that is created when you place a drawing title?  Currently we don't use these at all we just have a generic annotation that we've been using instead, but I wanted to try and make this work properly.
Chris
syman2000
Sadly view title cannot accept instance parameter. So you may have to make the grey bar long to accept your normal view title or not have it at all. It will not tie to the view title line extension.
ccasserly27WWJ
Yeah I figured this was gonna be the anwser. They should impliment text base parameters so you can link items to text length.
Thanks so much for your time!
syman2000
Yeah this is a short coming. However do add this to Revit Idea. That way it allows user to add this feature to next release if it gain lots of support
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
christopher.YR
@ccasserly27WWJ I've recently had a client ask for a line to have an adjustable length within their view title. While this solution isn't an exact fit, it can be a workaround. Basically I created a dimension from the ref plane to a ref line that was locked to the end of my line. Then I linked the dim label to a length type parameter with a selection of types set as standard lengths. For filled regions you'll need to lock the edge of your region outline to the ref line while in it's edit mode, otherwise it will move the filled region and not extend it.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
