Is there any way that when I drop a view on my sheet the view title displays on the top of the view instead of the bottom.
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
... hi @Anonymous
... sure
... just go to your sheet
... drop your view
... click on the view title tag of that view and turn it blue
... and move it wherever you want
... (not the view... just the view title tag)
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Thanks for your reply.
I was wondering if there's a way for that to be set. I have a large amount of sheets and views, that would consume a lot of time.
.. hi @Anonymous
... to do that you will need to create a specific view template
... but I think every view is different
... so it is better to move each title view to a desire position
... that way your sheet will look the way you want
... nevertheless...
You can create and edit view title types using the Family Editor. Revit provides several view title types. Some default view title types include sheet numbers and referencing sheet numbers to provide cross-referencing information between views and sheets.
The default view title types contain View Title in their file names. They reside in the following location:
%ALLUSERSPROFILE%\Autodesk\<product name and release>\Libraries\<locale and language>\Annotations
... but I never heard of that before ... ![]()
aRcHiTeCt.JM
REVIT EXPERT ELITE
