View title number not matching with the reference sheet number
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
jbPPU84
2479 Aufrufe, 3 Antworten
I starting using the view title that has the reference sheet and the sheet it is inserted. But I have some titles that are showing the wrong reference sheet number. How I can fix and settle that ?
3 ANTWORTEN 3
Nachricht 2 von 4
MostafaElashmawy
als Antwort auf: jbPPU84
Are you sure that both are reading the same parameter.
Open the title block family and the view head family and check that both are reading the parameter sheet number and that the sheet number.
Mostafa Elashmawy
Nachricht 3 von 4
Looks like A0.2 is the sheet with view where the section is cut. No?
Nachricht 4 von 4
in the label, there are two parameters related to sheet numbers:
Sheet number: read the sheet where the view is placed.
referencing sheet: read the sheet where the view was taken from (like the plan showing this section location)
make sure that you use sheet number in your case.Annotation 2020-01-14 013644.png
Mostafa Elashmawy
