I have been creating a quite a few sheets over the past few days with various views / elevations / details etc but I have a couple of views where the title is not showing:
The view on the lower left has been created no differently to any others yet is is missing the title like the one on the lower right.
I have checked the view type properties and the Show Title is set to yes. I have checked the view visibility and View Titles is checked so it is not hidden either.
How can I get this to show? Is it possible to add a view title to an existing view?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Check the viewport type see if it is different from others. If it is a different viewport type then change to the type showing view title. If it is the same viewport type then the view title maybe placed far away, zoom extent (ze) and drag it back.
Thanks @ToanDN.
All the same type...
The title was indeed off the page but strangely zoom didn't zoom out enough to see it and I'm suprised it printed out ok with the title block being the extents of the paper!!
In the end I just had to manually pan down and there they were ![]()
It happens when you place a view on sheet before cropping or changing scale. You can also remove the view from sheet and place it again and it's view title will be right below the view.
